TP in XNET
I am trying to implement ISO 15765-2 standard over the XNET 9862 hardware. I am aware of most of XNET drivers and sessions concepts but somehow couldn't able to implement TP over XNET hardware. My doubts is whether XNET hardware supports Transport Layer support for flow control and Multi-Frame information exchange. I can possibly try to do same thing on Application Layer but I believe it's not an ideal solution. I searched over ni.com and found NI ADCS tool which does the same thing but it's costly.
Has anyone encountered or tried to work on such scenario.
Thanks in Advance,
Vivek
(6,465 Views)
Comparing a development of a TP from scratch the cost for ADcS is not really expensive, even keep in mind that you can create free runtime licenses of your application when using ADCS
(6,438 Views)
Hi Gibson,
Thanks for your reply.
If that is the case as you suggested, then it's XNET is not worthy of it's cost. As more and more users nowadays use TP over CAN, buying a piece of software that only does specific job is not an option.
-Vivek
(6,428 Views)
