To perform a loopback operation on data using USB-CAN interface board (USB-8502)
Hello all,
I have a USB-8502 CAN interface device. Now, I want to develop an application to loopback the data sent from test device using USB port to USB-8502 device.
To be more precise, CANFD port-1 of USB-8502 device is connected to CANFD port-2 to have a loop connection for the data flow and see the acknowledgement back in test device over USB.
The test device is a WINDOWS-10 PC with LabVIEW software installed.
Are there any sample codes available to serve this purpose? or Can you please provide me any similar codes to serve this purpose.
Thanks in advance.
(2,224 Views)
in LabVIEW: Help -> Find Examples
  Hardware Input and Output -> CAN -> NI-XNET -> Loopback Test
(2,212 Views)
