Use of devicenet and CAN simultaneously
I am using Labview with a PCI-6527 DAQ card and PCI-CAN/2 card. I need to control a motor using devicenet and send CAN messages to another device.
Using NI-DNET, will give me only one port and make the other redundant. What options are there?
Do I have to buy two interface cards? and then would NI-CAN and NI_DNET give me conflicts?
I could use NI-CAN to access the DeviceNet network, but how difficult is that?
(3,637 Views)
Hi Elmo,
The problem is not the hardware. The two drivers cannot be installed together. You can only have NI-CAN or NI-DNET, not both.
At the moment there is no easy workaround. You mention using NI-CAN to implement DNET. This is possible, but you need the DNET specification to interpret the frames according to the DNET spec.
DiegoF
National Instruments.
(3,637 Views)
