Using Frame Output Stream Example with XNET Database...
I have an example based off the Frame Output Stream example. My example uses an XNET database with defined CAN cluster and messages. I know that for the streaming output mode the transmit time for the messages in the database are ignored. How do I  select a message from the database in LabVIEW so that I can send it on the bus using the streaming mode?
(5,266 Views)
Is your plan being able to send Signals from your database?
The XNET driver would also install several examples dealing with signals.
From the example finder, you can look into Hardware Input and Output >> CAN >> NI-XNET >> Intro to Sessions >> Signal Sessions.
AGJ,
NI
(5,245 Views)
