VCOM Toolkit FlexRay channel
I'm trying the new Vehicle Communication Toolkit, and when I generate the RBS xml configuration file for FlexRay, I need two parameters I'm not sure how to get: ChannelName and HWChannel.
Accessing a FlexRay database, the XNET Cluster Property Node shows the FlexRay.Channels property, which is a U32 enumeration. According to the documentation:
The values (enumeration) for this property are:
1 Channel A only
2 Channel B only
3 Channels A and B
However, I don't see any more references to channels, and I don't know hot to translate this to the RBS parameters needed.
Reading the database as text I can see:
<fx:CHANNEL ID="channel1_A" xsi:type="flexray:CHANNEL-TYPE">
<ho:SHORT-NAME>Channel1_A</ho:SHORT-NAME>
I'm guessing Channel1_A could be the value I need for ChannelName, and maybe A could be HWChannel, but I get the error:
Error: AutosarCfg (Code: 304): Channel A not found
Does anyone know where to get these values? I don't know much about FlexRay.
Thanks!
Kindest regards,
Néstor
LabVIEW 2022 + DIAdem 2020 + Windows 11
(2,423 Views)
Hi JoePerkins
Considering on error code description you should check for proper spelling using MAX; For Get/Set Property, ensure that the channel name exists in the task.
Also, here is another forum post which can be helpful in this case.
Regards)
(2,088 Views)
