Vector CAPL - Bit-Shifting of 2 values
I have the following problem:
I want to write a function in CAPL that takes two numbers (e.g. num1 = 521404 num2 = 5) and does the following:
num1 as bit is: 0111 1111 0100 1011 1100
num2 as bit is: 0000 0101
My result shall be FF E5 F4 BC (= 1111 1111 1110 0101 1111 0100 1011 1100)
Could someone help? I managed to write it as C# code but I have no idea how I could write in down in CAPL. It is not a test node in CAPL so I also didn't manage to include my C# dll.
Maybe someone can tell me how the code would directly work in CAPL? Unfortunately I don't have any C experience...
Thanks a lot!
(9,612 Views)
What is your hardware and software setup?  Could you outline what NI hardware or software you are using?
Regards
(9,597 Views)
as you are using Vector Software (CANoe?) you should contact your local Vector support
(9,595 Views)
