Very Urgent : 9853 and 9852 Output Path FIFO Size
In the  9852 and 9853 Help it is written, in the Arbitration chapter :
The output path is implemented as a FIFO. This allows multiple frames to be sent to the CAN module for transmit, thus enabling tests that generate full bus load.
I need to know the size of this FIFO, in fact the number of frames I can put in the output node before it is full. I've in mind that it's 17 but I cannot find where I read thisinfo.
could you confirm it ? and tell me where I can find this info ?
Pierre R...
Certified LabVIEW Developer
(8,102 Views)
OK I've found : this KB
Pierre R...
(8,099 Views)
I am new to the crio and labview RT.
i am using 9012 RT controller, 9103 CRIO and 9853 CAN card.
I have created the FPGA project, created a FPGA and Realtime VI. I have straightly connected CAN0 and CAN1. CAN1 is powerd with 10v.
the FPGA vi is deployed and the Realtime vi is complied.
Now if i click on the transmitt button in the relatime vi, i am not getting any message.
I have attached the project folder.
Its very urgent for me. pls do respond.
waiting for the reply,
 Yogesh
(7,900 Views)
I think so.
(6,937 Views)
asdasd
(6,936 Views)
HELLO
(6,934 Views)
HELLO
(6,934 Views)
