What exactly is the ECC Register ?
After performing a low temperature / altitude test on a piece of equipment, our CANbus log showed that several Rx errors had occured during the test and the ECC register showed a value of 243.
Can anybody tell me what the value in this register means?
Andy
(13,252 Views)
ECC is the Error Code Capture register of the SJA1000 chip. If you aren't using NI-CAN  hardare you may have a different chip and it may also have an ECC register that may be different.
243 = 0xF3 = 11110011
From the SJA1000 manual (see nxp.com)
Bits 7:6 Error Code = 11 = 'other type of error'
Bit 5 Direction = 1 = 'RX; error occurred during reception'
Bits 4:0 Segment = 10011 =  'tolerate dominant bits'
From Application Note 97076 (see nxp.com)
tolerate dominant bits should be with a form error and means that dominant was detected on the bus for more than 7 bits times after active error flag or overload flag.
Since you didn't get this segment with a form error, I am pretty confused.  Are you certain about the 243?
(13,246 Views)
