System Properties: Win2000, LabVIEW 7, 100bT LAN
- Successfully accessed the WebDAQ/100 over the LAN using IE.
- Using TCP/IP, a connection over the LAN can be established, but data commands are inoperative.
- Using the ActiveX WebDAQ refnum (WEBDAQLib.Webdaq) with the WebDAQ/100 hosting, error # -2147023174 - "The RPC server unavailable" appears from the Automation Open subVI.
- With the above mentioned RefNum but locally hosting, error # -2147418113 - "Catastrophic Failure" appears from the Automation Open subVI.
Attached is the WebDAQ DLL used in the above mentioned trials.
