What is exactly error CanWarnCommStuff?
Well, I have the same message when i use low or high speed and i try to read a message from the microcontroller.I don´t know if the problem is because i connect something wrong(the port) or it can be another problem such as noise.When i trasmit a message i can see it in the bus with the osciloscope.
I am using a PCMCIA and a CAN/DS cable, and i am connecting CAN_H ,CAN_L and V-(ground).
(3,675 Views)
A stuff error is when 6 or more bits are detected with the same value. The CAN especification uses bit stuffing. If the transmitter detects a bit string of more that five bits with the same value, it will add a bit of the complementary bit value.
According to the CAN spec"
"STUFF ERROR
A STUFF ERROR has to be detected at the bit time of the 6th consecutive equal bit
level in a message field that should be coded by the method of bit stuffing."
Check the Bosch CAN homepage for the specification document.
DiegoF
National Instruments.
(3,674 Views)
