What is the best card to implement a protolo CAN
Hello
I am an insider in Labview.
I need implement a protocol by CAN.
The reading will be done through a board controlled by Labview.
The communications are basic, to test an electronic board
What is the best card to implement a protolo CAN?
(6,210 Views)
There are a lot of CAN cards that you can use with your application. I advise you to have a look at www.ni.com/can .
What kind of cards do you want to use ? PCI cards ? PXI cards ?  What is the speed you want to reach ? How many ports do you want ?
As you can see there are a lot of parameters that depend on your application and what you want to do.
(6,184 Views)
