What's the fastest way to rotate an image?
I need to perform a rotation on an array representing an image. The angles are random between 0 and 90 degrees. The fastest way I found is with IMAQ. But that means converting the arrays to an IMAQ image first, then rotating and then again converting back to array. There must be a faster way, because probably IMAQ itself converts the image back to an array to perform the rotation. I implemented the classical algorithm of shear-transpose-shear-transpose, but that's 10 times slower than the IMAQ routine.
A special case for rotating under 45 degrees might also be interesting for me.
Thanks.
Certified LabVIEW Developer (CLD)
(4,319 Views)
Hi Manu,
You have submitted your question to the Industrial Networks>Ethernet forum. Your question really doesn't have anything to do with Ethernet communication. I think you will be better served if you resubmit your inquery to either the Vision Exchange or a forum more closely related to the programming environment which you are using.
-Chad
(4,319 Views)
Yeah I know, I pressed the wrong button and didn't find a way to delete the post. But thanks anyway 😉
Manu.
(4,319 Views)
