Why do my CAN card send a ERROR FRAME
When I use my can application everything is working perfekt but if I connect a CAN alyzer to the bus it display a ERRORFRAME. So does this ERRORFRAME apper and what does it mean?
//Olssoninc
(4,247 Views)
The error frame means that a network member has detected an error and destroid the message by causing 6 resessive  bits, called a Error Frame.
Thus it seems something is wrong with one of your network nodes or with the cabeling or termination.
DirkW
(4,235 Views)
