Wrong period of CAN message when using veristand
    I use Veristand. The period of CAN message is set to 10ms and the other is 100ms. After loading the project into PXI platform, the real transmission period is different. There are no rules about the period. The baud rate of CAN is 250Kb/s. And the real period of CAN message is monitored by Kavasar.
    Is there any body, who has faced with this problem?
(6,086 Views)
What hardware are you using? What rates are you seeing? Are you sure that the Kvaser hardware is correct?
(6,083 Views)
Real time processor is "PXIe-8135". CAN board is "PXI-8513/2". High speed can and 250Kb/s is used. Karvasar works well and is validated by other CAN instrument.
(6,074 Views)
