XCP CCP Custom Device Communication errors
Ok the mistake was not to reopen the Workspace. That solves the problem.
I think is the normal proccedure to do with Veristand but I still get the error 74.Error74_en.png
Everything works fine but I still get this error sometimes at the beginning for every measurement/Characteristic. But they do work.
Should I open a new Post?
[Edit]: Is there any way to do in Veristand what this "XCP Set Cal Page.vi" does in LabVIEW?
Solution: In this case I don't need what the second VI does, only the first. And the Configuration can be changed in Veristand.switch_calibration.png
My Channel: https://www.youtube.com/@LV_Lab
Message 21 of 23
(1,033 Views)
I'm using NI PXI-8231 Ethernet Card now,and I wonder how u discover or build the CD, is there any tutorial?
Thanks!
Message 22 of 23
(838 Views)
What is your issue? I explain here how I build the CD. https://forums.ni.com/t5/NI-VeriStand-Add-Ons-Discussions/Diagnostics-Custom-Device-installation-pro...
If this doesn't work, you can message me private and I can search a PDF I made for the company i was working for.
Message 23 of 23
(834 Views)
