XCP Master on LIN bus
Does NI ECU Measurement and Calibration Toolkit support XCP on LIN bus?  The datasheet shows only CAN and Ethernet, but hopefully this is wrong. If not, is there a plan to support the LIN physical layer?
(8,802 Views)
Hello dualtronic,
The datasheet is correct...we do not support XCP on LIN yet.
We are considering many things for future versions of the toolkit and XCP on LIN is something we are considering, but I don't know if or when it will be available.  I'm sorry about that.
O. Proulx
www.ni.com/support
(8,768 Views)
Any update on this?  Is there a solution for XCP on LIN yet?
(7,837 Views)
Currently looking into this - I'll let you know
David H.
(7,817 Views)
Just received an answer on this - We do not support XCP for LIN in the ECU Toolkit
Thanks!
David H.
(7,727 Views)
So to my question.  Is there a solution for XCP on LIN yet?  The answer is no, correct?
(7,721 Views)
Correct - The answer is no
David H.
(7,714 Views)
