XNET CAN Channel Order
How does XNET determine the order CAN devices are numbered?  For a PXI system, it does not seem to be the following:
  • slot number
  • serial number
In addition, the channels are not listed in ascending order for the XNET session controls.
CLA, CTA
(6,885 Views)
How do your CAN Devices appear in MAX?  What CAN devices are you connecting to?
If you create a constant on the block diagram of the channels do they give you the same order, random, or in ascending order?
M. Whitaker
ni.com/support
(6,870 Views)
The MAX configuration is sorted by CAN channel where the XNET constant (same as control) channel order is not as seen below:
I would prefer not to post the device serial numbers in a public forum.  Please let me know if I should continue this with a support request.
CLA, CTA
(6,853 Views)
Thank you for that information.  A Corrective Action Request, #415101, has been filed regarding this behavior.  The best way to learn about the progress of the CAR is by contacting support after some time to get any updates.
M. Whitaker
ni.com/support
(6,831 Views)
