XNET Flush.vi not working on J1939?
Hi NI,
I spent most of the afternoon troubleshooting a strange error with the XNET Flush.vi that did not sem to behave properly. After much investigation, my tentative conclusion is that some of the following:
 - A XNET session is opened as "Frame Out Stream"
 - With a cluster defined as ":can_j1939:"
 - And you send messages that have a payload of 8 bytes or less
 - On a bus that is empty (i.e. no other CAN device to acknowledge)
At times, cause these results:
 - Property node XNET Session -> Number Of Values Pending ALWAYS returns zero (0)
 - XNET Flush.vi doesn't work and after a period long enough, you get error -1074384888
If I change my payload to 9 bytes or more, then both the property node and the Flush work. [Edit: This is not always the case in the end. However, sometimes it helps the buffer works...]
This has been nagging me on both XNET 15.5 and 16.1. Are there any open CAR about the Tx Buffer for J1939 sessions?!?!
Olivier
Refrence
Error -1074384888 occurred at an unidentified location
Possible reason(s):
NI-XNET:  (Hex 0xBFF63008) A write queue overflowed. Solution: wait until queue space becomes available and retry.
(3,891 Views)
Did you solve the problem?
My Channel: https://www.youtube.com/@LV_Lab
(3,258 Views)
This is currently on our known issues list. When fixed it will be listed in the readme as issue 630730.
Jeff L
(3,255 Views)
