XNET Read error -1074384864
I'm trying to read multiple frames from my CAN bus using XNET sessions. For every frame, I use a "XNET Read (Signal Single-point).vi" in the frame of a sequence (see screenshot).
I'm always getting an error for the second read! Both sessions use the same dbc-file.
Note: I'm NOT getting an error if I read exactly the same value (=same session name) in both calls of the Read VI.
Message 1 of 1
(2,228 Views)
