 FaustoTromba
			FaustoTromba
			11-19-2015 12:36 AM
Hi
I'm new to use XNET. I did a program to write and read the Diagnostic command.
I loaded the .ldf file in the XNET, but sometimes the all works properly and sometimes not. The program crash always after the first Diagnostic command to send and to read.
The unique solution till now is to reload the .ldf file on the XNET.
If XNET is open, the Labview program crash. But if I open the drop down menu of XNET, File-->>Save, the Labview program runs without any problem.
It seems like they XNET loses the ldf file
Thanks in advance
Fausto
11-20-2015 07:25 AM
Hi Fausto,
do you get any specific error message or does LabVIEW just crash?
Could you please post the code, that reproduces the issue?
Melanie
