XNET reset session
Hello all
I developed a TestStand séquence using CAN FD XNET session (LV202164 bits, TS 2021 64bits, XNET 21.8). The sequence ran with Parallel processmodel (6 UUTs in parallel, 1 CAN interface for each UUT)
Sometime, when communication error happened due to UUT tested the “XNET Clear” doesn’t work properly and then when I restart sequence, I systematically have the following error :
NIXNET:  (Hex 0xBFF6309A) The interface has already been opened with different cluster settings than the ones specified for this session. Solution: Make sure that the cluster settings agree for the interface, or use a different interface. [Error Code: -1074384742]
The only solution to reset this error is to exit TestStand (which unload all libraries)
Is there a solution to reset all XNET session used by an Interface without having to restart Software ?
Thank you for your help
JP
Message 1 of 1
(891 Views)
