XNET support 903x (9035)
I created a LabVIEW project with a 9035 in it and right click the chassis and went to new -> C series modules. IN the drop down box I tried to select a 9862 but it was not present in the list of options. Looking at the XNET readme and 9862 product page, they both list support for 903x cRIO chassis. Why can't I create a 9862 module under the chassis of the 9035 in my LabVIEW project then?
LabVIEW 2014 SP1
XNET 14.5
RIO 14.5
Thank you!
Stephen B
Message 1 of 9
(7,630 Views)
According to the product page the information you posted is correct.
https://www.ni.com/en-us/shop/model/ni-9862.html
That being said it also states you need LabVIEW FPGA installed.  Do you have that installed too?
Message 2 of 9
(7,623 Views)
Yes
Stephen B
Message 3 of 9
(7,615 Views)
Hi Stephen,
Are you using simulated hardware in your project, or connecting to your actual 9035? For simulated hardware, you should be able to add a 9035 under the chassis (not FPGA). If using real hardware, you might need to compile and run a blank bitfile on the FPGA.
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
Message 4 of 9
(7,606 Views)
Please see my original post. I listed exactly what I was doing there.
Stephen B
Message 5 of 9
(7,602 Views)
The issue is becoming urgent as our hardware arrives soon and I'm afraid I wont be able to use it. Please, can someone from NI take a look? Thanks!
Stephen B
Message 6 of 9
(7,584 Views)
Smiley Indifferent...uh aren't you someone at NI?  Your name and participation level are blue like NI employees.
Message 7 of 9
(7,580 Views)
Former. No idea why they haven't updated it
Stephen B
Message 8 of 9
(7,575 Views)
Accepted by topic author StephenB
Reinstalled XNET and it fixed it. Woohoo!
Stephen B
Message 9 of 9
(7,562 Views)
