XNET write function for selected frames in CAN database
Hi All
I am newbie in CAN XNET programming and would like to have your inputs on the following question.
I have created a can database in XNET database editor and has exported it to .dbc file.
This database has near about 100-150 can frames data defined in it (along with the signal details).
In code, I have used XNETcreate session.vi (mode : Frame output single point) to create sessions for all the frames which are present in database.
Based on request from Master CAN node , I need to send data from specific CAN frames over the CAN network.
I am using XNET write function for it.
Issue I am facing is , "session in" input for XNET write is nothing but "session out" output of create sessions.vi.
Whenever I am calling XNET write  function , the data is written to all the frames which are defined in database.
Instead of that , i need to transmit data only by the selected CAN frames.
How can I achieve this functionality? where can I define which frames from the database should be transmitted on the CAN network?
Attaching sample VI and .dbc file here.
Note : .dbc file is uploaded as .txt . To view it as .dbc , change the extension to later.(i.e to .dbc)
Thanks in advance.
(2,797 Views)
Have you found any solution to your problem? I see nobody replied to your query. Fyi, I am not able to open the CAN_db.dbc file in NI XNET database editor? can share the lastest one.
(2,074 Views)
