XNet Muxing
Hello FixedWire
I found the CAR#443367 where this issue was reported. The Workaround: Ignore: though the Editor will throw that red X, the signals should work fine.
Is it working fine or not in your end? Even if you see the x mark...
Regards
Frank R.
Message 11 of 13
(3,085 Views)
Thanks fromm8. The signal doesn't become available in LV as a dropdown option and will throw an error.
Message 12 of 13
(3,076 Views)
NI-XNET supports Signals with a size of max. 52 only. See the NI-XNET Hardware and Software Manual for further information
eg the Signal Property "Number of Bits" explains that pretty accurate
The number of bits the signal uses in the frame payload. IEEE Float numbers are limited to 32 bit or 64 bit.
Integer (signed and unsigned) numbers are limited to 1–52 bits. NI-XNET converts all integers to doubles (64-bit IEEE Float). Integer numbers with more than 52 bits (the size of the mantissa in a 64-bit IEEE Float) cannot be converted exactly to double, and vice versa;
therefore, NI-XNET does not support this. This property is required. If the property does not contain a valid value, and you create an
XNET session that uses this signal, the session returns an error. To ensure that the property contains a valid value, you can do one of the following:
 Use a database file (or alias) to create the session.
The file formats require a valid value in the text for this property.
• Set a value in LabVIEW using the property node.
This is needed when you create your own in-memory database (:memory:) rather than
use a file. The property does not contain a default in this case, so you must set a valid
value prior to creating a session.
Message 13 of 13
(3,072 Views)
