bus monitor
Hi ALL,
How can bus monitor be developed for CANOPEN protocol where when I create SDO i get messages of the SDO things and when i create a PDO or sync or EMCY I get messages of that.
CANOpen is must and not CAN frame api.
The bus monitor should imitate the Ni-MAX bus monitor.
Thanks is advance.
(5,401 Views)
The CANopen Library for LabVIEW doesn't allow to use the NI-CAN Frame API in parallel on the same Port. Thus you would have to use the second port of your board or a second board to programm your Monitor using the NI-CAN Frame API.
DirkW
(5,394 Views)
