cRIO CAN 985x, Reset and TimeStamp after bus off
Hello ,
I'm working on a HIL project that's able to manage 5 CAN bus using cRIO in order to be able to restart quickly the communication after a bus off state.
My question is easy 🙂 .
After a bus off , in order to restart the communication, it's needed to : Reset the SJA, reapply my Transceiver config and START it. My problem is the following, after a reset, the transceiver timestamp is erased. All my system : DAQ, LIN, CAN ... is synchronised by a pulse on RTSI0 that allow me to synchronise all my elements. The problem is that after a reset my CAN is no more synchronized, and the timestamp is not valid with the rest of the system.
A workaround that I use for the moment is to have my own SCTL(10MHz) that generates TimeStamp since the pulse on RTSI0 and I systematically replace the SJA TimeStamp in my CAN Data by this timestamp, but for me it's not a really good solution.
do you have any idea ?
Message Edité par pierreR le 06-26-2008 04:12 PM
Pierre R...
Certified LabVIEW Developer
(6,457 Views)
Hi Pierre Smiley Very Happy,
I guess there isn't any other solution to the issue you are experiencing. I didn't find informations about this, except this KB : Synchronization with NI 985x cRIO CAN , but you may have already seen it. I'll have a better look at it this time next week and I'll keep you in touch.
(6,448 Views)
Hi Maxime,
I saw this example, but in my case, I don't have an offset between my processes until a bus off on one of my CAN port.
My workaround with an SCTL which is counting is working, but I wanted to know if someone has a better way.
I sent an email to Ian Fountain the RT&FPGA BDM for Europe. I hope I'll have an answer on monday.
Thanks, and have a good day
Bye bye
Pierre R...
(6,433 Views)
