can error
I receive these errors, white someone the correct konfiguratin for CAN NI PXI 8464, I work in a NI PXI as remote system with labview RT  8 and CAN 2.3.2
Fehler -1074388957 ist bei CAN Initialize.vi aufgetreten
Mögliche Ursachen:
NI-CAN:  (Hex 0xBFF62023) Stellen Sie sicher, dass dem Interface im Measurement and Automation Explorer (MAX) unter 'Geräte und Schnittstellen' ein spezifischer CAN-Port zugeordnet ist.
 thanks.  befaiz
(4,114 Views)
Befaiz,
as far as i understand the error-description and your infos in the posting, you are using a remote PXI-system which is running on RT. I asume that the programming language you are using is LabVIEW.
Within the PXI-system, you have a 8464, which does not work correctly in your RT-application. Due to the error-message, there is some issue with the driver trying to access the 8464. So either the driver is not properly installed on the RT-system or you missed some neccessary settings for the device within the MAX of you hostsystem. Please check these settings.
Norbert B.
NI Germany
Norbert
Expert: Geometry
(4,048 Views)
