I am trying to test many units with same id in a lin network. My slave is a switch module used in cars. I need to test 10 units is parellel and was wondering if i can use one usb 8476 and communicate with the 10 units at the same time ? I need to read the data from the units and analyze it to check a particular bit is activated or not during the test.  Is there any way that i can buffer the data from each of the units and check the data for the particular bit ?
From what i know, in lin we cannot connect two units with same id to the same usb 8476. But i was wondering is there a solution to this problem ?
Can anyone help me with this ?
Thank you.
