can receive vi
Hi guys,
i'm workin with the NI 9862 module and labview 2011 . i run with no problems the  CAN receive VI  example, but i would like also to save my readings into a file. SO far i tried to use the write to  measurements file and write to spreedsheet file but i couldn't make it work.
is there a way to make it work?
thanks
(6,221 Views)
I would look at the logging TDMS examples that ship with NI-XNET.
(6,213 Views)
thanks for your reply i will check it right now
(6,196 Views)
