I need to create a ramp of data frame : using a NI CAN board, i would like to know how to generate a data frame of 40ms , at each period , the data have to increase ( of 10 units fo example). Actually I need to  simulate several frames (some have fixed data) and for two of these frames, i have to create a ramp ( ramp 1 : period 40 ms, ramp 2 : period 100 ms). Is it not possible to use the board like an MIO continuous buffered generation?
What do you think of using the channel API instead the frame API?
