cheap remote IO devices for devicenet
I want to extend an existing DeviceNet network to control a light tower (8 DO's). I am having a hard time finding a simple cheap DI/O unit to accommplish this. If I want to go to 24 bits plus some analogs, there seem to be plenty, but way above my budget. I would prefer a unit with a termination block vs 12mm screw ins.
Anyone with any ideas?
robot
(4,558 Views)
Hello-
If the task is to toggle some DO's at a set frequency, Cutler-Hammer probably has a timing circuit that's not too expensive. If the DO's need more control, the Fieldpoint 2000 (FP-2000) has an embedded controller that can be accessed through Ethernet. Unfortunately, most DeviceNet devices have CAN circuitry that is not cheap.
Randy Solomonson
Application Engineer
(4,558 Views)
I've used Automation Direct Terminator I/O -- it's like AB Flex I/O but cheaper. You can get into a 16 pt DO Module for < $400. You can mix and match DI,DO,AI,AO. Check out their website. I've used it with LabWindows (have to give an NI plug here) with success.
(4,558 Views)
Have you looked at the AB 1790 compact block LDX ? They are small, cheap and you can stack them up lots of different ways. Once you buy a base module , (list about $250) you can add 3 more modules and the add ons are even cheaper
(4,158 Views)
