configure
I use PCI-CNA SERIES2 and C Language.
How to configure to only receive standard frame?
How to configure to only receive entended frame?
(5,009 Views)
The following Attribute configuration for Comperator and mask  disables Standard Frame reception. Only extended Frames get received.
AttrIdList[4] =         NC_ATTR_CAN_COMP_STD;
AttrValueList[4] =      0xCFFFFFFF;
AttrIdList[5] =         NC_ATTR_CAN_MASK_STD;
AttrValueList[5] =      NC_CAN_MASK_STD_MUSTMATCH;
AttrIdList[6] =         NC_ATTR_CAN_COMP_XTD;
AttrValueList[6] =      0;
AttrIdList[7] =         NC_ATTR_CAN_MASK_XTD;
AttrValueList[7] =      NC_CAN_MASK_XTD_DONTCARE;
The following Attribute configuration for Comperator and mask  disables Extended Frame reception. Only standard Frames get received.
AttrValueList[4] =      0;
AttrValueList[5] =      NC_CAN_MASK_STD_DONTCARE;
AttrValueList[6] =      0xCFFFFFFF;
AttrValueList[7] =      NC_CAN_MASK_XTD_MUSTMATCH;
This is described within the NI-CAN manual on page 11-11 and 11-12.
DirkW
(5,002 Views)
