different codes for writing and reading in CANOpen.
Your device the 8743 does not support CAN Open.
This article lists the NI CAN devices and their supported API's
If you have another NI CAN device you will need to install
the CAN Open library and open the examples.
Christian A
Message 21 of 22
(3,596 Views)
Thank you for checking this! I saw that the PCI version could be the solution but instead I ordered it USB version believing that it'll also work fine... Anyway I don't use LabView and anyway I couldn't use CANOpen libraries. Unfortunately I'll have to look for another Canopen manufacturers. 😞
Best regards
Message 22 of 22
(3,587 Views)
