error 1074388952
Hai
     I get an error 1074388952 message in the attached VI, how to eliminate this error.
sk
________________
I am using LabVIEW 7.1 & NI PCMCIA CAN hardware
(3,684 Views)
First, if you use the read mult , you need to specify a read queue length. The error indicates that you got to much frames to fast. Thus it is better to enable the filter rigth at the beginning. I modified your example that way.
DirkW
(3,669 Views)
