ez430 RF2500
Hello everyone,  i am new to Rf2500 , when i am trying to run the demo program that cam in the cd , "bsp.c" file gives an error. the error is listed as"Error[Pe147]: declaration is incompatible with "int __low_level_init(void)"   Can you please help me regarding this?
(7,228 Views)
Which development tool are you using. And also which code are you trying to run.
(7,217 Views)
ohk man, i am done with it. i somehow corrected the code and got the output.
now, i want to implement a project such as to transfer the signal using a push button to the end point and thus lighting a led on the EP.
Can you suggest me some code or any source?
moreover, i am using IAR workbench so as for compiling and debugging.
(7,214 Views)
What did you do to get this error to go away? I am seeing the same thing.
I am running IAR EW430 compiler version 5.10.6 and am trying to compile the CC2500 Sensor Demo Access-Point project.
Thanks.
Mike
(6,953 Views)
