filtering can frames with frame api (part 1)
I have problems to understand the filter techniques in the frame api for C/C++.
My current structure is as follows:
- I have a NI CAN Card (Series 2 HW, Philips SAJ 1000 Contoller, 1 CAN Interface (CAN0))
- On the CAN BUS Interface one target device is connected (it is a controlling unit for a sliding gate, automotive)
- I 've created 2 CAN Network Interface Objects, one for receiving, another for transmitting frames
- all received Frames from the target (incomming frames) are handled by the receiving Object.
- its configuration is as follows:
            m_attrList[0] =       NC_ATTR_BAUD_RATE;
            m_valueList[0] =    83333; //CC.NC_BAUD_100K;
            m_attrList[1] =       NC_ATTR_START_ON_OPEN;
            m_valueList[1] =    NC_TRUE;
            m_attrList[2] =       NC_ATTR_READ_Q_LEN;
            m_valueList[2] =    0; //number of frames (not bytes!)
            m_attrList[3] =       NC_ATTR_WRITE_Q_LEN;
            m_valueList[3] =    0;
            m_attrList[4] =       NC_ATTR_COMP_STD;
            m_valueList[4] =    NC_CAN_ARBID_NONE; //handle all frames that are not handled trough CANObjects //CC.NC_MASK_STD_DONTCARE;//0x791;
            m_attrList[5] =       NC_ATTR_MASK_STD;
            m_valueList[5] =    NC_MASK_STD_DONTCARE;//0x791;
            m_attrList[6] =       NC_ATTR_COMP_XTD;
            m_valueList[6] =    NC_MASK_XTD_DONTCARE;
            m_attrList[7] =       NC_ATTR_MASK_XTD;
            m_valueList[7] =    NC_MASK_XTD_DONTCARE;
- opening it as follows:
            iStatus = ncConfig("CAN0", 8, m_attrList, m_valueList);
            iStatus = ncOpenObject("CAN0", objRXHandle);
- I 've configured it with ncCreateNotification(objRXHandle,...), so on any received frame a callback is invoked.
- no remote frames are used, since the target doesn't support them.
- similarly I've defined the transmitting Object, but not opened it, because I do the transmitting via CANObjects (one per ArbID)
- frames are only received after a command is written to the target (calling ncWrite(...)) within a manufcturer specific frame for a CANObject
- up to now all fine
- now I want a filter mechanism wich allows me to define a list of ArbIDs that must not be processed
- my intention was to define the attribute and value of the receiving CAN Network Interface Object (as mentioned above):
(...please continue on part 2)
(3,593 Views)
for answer see part 2
DirkW
Message Edited by DirkW on 01-10-2006 04:01 PM
(3,579 Views)
