how to encode data in CAN to transmit message
Hi all,
I have to encode two decimal no's  and has to transmit through the CAN,,so not getting how to code this in CAN data field,,,if anyone know please reply,,
thank you
(6,805 Views)
Hello Shoukat,
I have attached a VI that should help you make the conversion from a floating point number to an 8 byte array.  You can use less than 8 bytes depending on the precision of your float.  You can decode this by doing the inverse, using the index array and join numbers VIs.
Depending on which hardware you are using, you can also use the channel API to easily make this conversion by creating a channel in MAX.
Let me know if this answers your question.  Have a great day.
O. Proulx
www.ni.com/support
(6,749 Views)
thanks for reply,,
 can you please send same  vi in labVIEW8
thank you
(6,743 Views)
This should work.
O. Proulx
www.ni.com/support
(6,728 Views)
