i am new to labview. i am developing DAQ system in Labview 8.2.But in that i could not eneter column names and header names.and also i could not able to write the data
  I am new to labview. i am developing DAQ system in Labview 8.2.But in that i could not enter column names and header names.and also i could not able to write the data. . please give me suggestion
(6,411 Views)
Hello 080...
First off, I would suggest only posting once.  I would also suggest putting more detail on what you are trying to do.  Your post is very vague.  What do you want to add column names to?  What do you want to write data with?  To a file?  To a DAQ device?  It would also help if you posted the VI you are working on.
Also, keep in mind that this forum is called the "Automotive and Embedded Networks and Industrial Communications"...which does not seem to have much to do with your application...You might get faster replies in the LabVIEW or DAQ discussion forums.  (But they will also ask for more details!)
Have a great day.
O. Proulx
www.ni.com/support
(6,386 Views)
thanks O. Proulx this is hardly 4th time i used this forum
thanks for ur suggestion
i will try in DAQ forum with details
(6,370 Views)
