i get an error in using ncWatiForState,how to solve the problem?
I recuperate a  CVI code (obj2obj) in examples, in order to receive CAN data. However, I met an ERROR,
It shows:
(Hex 0xBFF62001) means the timeout of a wait or notification function expired before any desired state occurred.
Solutions: Increase value of Timeout parameter; Verify your cable connections and operation of remote devices
But if the other OBJ didn't  send data,how to solve this ERROR?
I means that i want to get my program continue  running without/after this error be solved?That is if time is out,it jumps to next line。
(6,239 Views)
You could ignore the timeout for the wait and just case to the next function you wnat to call if a timeout ocures. Thus you would not call the read function in a timeout case.
Or you could loop into the wait function again to wait another timout until the frame you expected has received.
DirkW
(6,163 Views)
