labview misses a read when using Ni USB 8473 can interface
Hi
Matt
I am a new NI 8473 user I can't even find ncWaitForState.vi, nc Close.vi, ncConfigCANNet.vi .... and more
Do I need to purchase these?
JP
Message 11 of 14
(740 Views)
Download and install NI-CAN. It is the drivers that make your hardware work.  A CD should have came with the hardware.  Here is the latest which might not be appropriate depending on what version of LabVIEW you want to use it with.
https://www.ni.com/en/support/downloads/drivers/download.ni-can.html
Message 12 of 14
(730 Views)
Thanks!
I've installed NI-CAN and NI-MAX showed NI-8473 drive install correctly but could not find the following VIs.
ncAction.vi
ncClose.vi
ncConfigCANNet.vi
ncConfigCANNetRTSI.vi
ncConfigCANObj.vi
ncWaitForState.vi
Is it in a specific location can you please tell me.
JP
Message 13 of 14
(715 Views)
Search your block diagram palette.  Or search the Help >> Find Examples.  I believe it is under Measurement I/O.
Message 14 of 14
(708 Views)
