ncSetAttribute, USB-8473
I'm trying to use the ncSetAttribute to turn on the debugging modes of the USB-8473.
However, there is an apparent "chicken vs. egg" issue in the interface.
 To use the ncSetAttribute, I need to stop the interface.  The only way I know to stop the interface is to use ncCloseObject.
If I call ncCloseObject, then  my ObjHandle is invalidated.
However, I need my ObjHandle to call ncSetAttribute.
If I call ncSetAttribute before calling ncOpenObject, then I don't have a valid ObjHandle to pass to ncSetAttribute.
How is this supposed to work??
(7,211 Views)
Please look at the following link on page 11-18.
http://www.ni.com/pdf/manuals/370289j.pdf
If you call ncSetAttribute before sending your packets you should be fine.
Are you using LabVIEW? What version?
Sammy Z.
(7,196 Views)
I forgot to post earlier.  I figured it out.  I need to call ncAction to stop the port after opening it with ncOpen.
I don't use labview.
It would be nice if NI did a better job with the C chapter of the manual.  There are lots of errors in it.  You end up looking at the labview chapter and trying to decide if the C code should really work like the labview code or if they are supposed to be different.
(7,191 Views)
Hello anAlias,
Please feel free to let us know the errors you found and we will make sure they are corrected in future versions of the manual.
O. Proulx
www.ni.com/support
(7,189 Views)
Hi anAlias,
I'm glad your issue is solved and thank you for your input.
Sammy Z.
(7,166 Views)
