ncWriteMulti Issue
Hi Aid,
I have not seen such a behavior before, but it sounds like the data gets corrupted within the driver memory somehow.
You could help us debugging this if you would create a Spy Log File for the ISSUE.
First download and install the NI-CAN 2.3.3 or 2.4 driver. The driver brings a software tool called NI-SPY. The Spy is able to log all API calls, thus you can see all data passed to every single function call and the return as well.
In the End you can save the file to disc, zip the file and send the file to canpse@ni.com.
Before you run the SPY, configure your application to use a single write for transfer and stop if the timeout occurs. That makes it easier for us to debug. If possible, run the monitor on a different machine, thus we do not have to log these function call as well. Then open the SPY Logger and stop the logging with pressing the red X. Now go to Spy>>Options.
On the first page (general) change the settings to "Call history depth" = 50000, "Large Buffer" and "Extended". On the View Selection page select only NI-CAN on the right pane. On th error action page select "continue capturing, ignore error"
Now start the Logging with pressing the blue arrow and run your application. Your application should stop if the timeout occurs, what means the transfer failed. At the same time the spy should stop.
The log file should tell us which write call failed and why it failed.
DirkW
Message 11 of 13
(1,626 Views)
No I don't -- I'm kinda new to the boards.  I suggest you post a question on the LabVIEW board.  It's a very high traffic area.
Tom
Message 12 of 13
(1,623 Views)
Hi Dirk,
            Just a quick update, I've taken a Spy log of the issue and sent it together with the associated Bus Monitor stream to the specified email address. Looking at the Spy log it appears that the data passed to the ncWrite function is correct.
Aid
Message 13 of 13
(1,611 Views)
