neovi labview example
still the problem for the neoVI Labview example.
i can receive the message from another software, but i can't transmis the message.
i always arrive the good result:
thank you
(7,484 Views)
Hello summerwar,
Are you talking about this?  If so, I could not find much information on their website or in your post, so it is difficult to know what is going wrong...
By the looks of it, I'm guessing you are using the serial port of your PC to connect to their device which converts these to CAN messages.  If you cannot transmit any messages, maybe your TX line is not connected properly to the RX line on the module.  What kind of cable are you using?
Do you know if you need to send a command to represent that you want to send a message?  Its difficult for us to help without the VI and the product manual at least.
I hope this helps...
O. Proulx
www.ni.com/support
(7,468 Views)
I am trying to interface NeoVI with LabVIEW. Can one share the NeoVI LabVIEW example.vi.
---------------- Be Good. Do Good. ---------------------
(6,672 Views)
