nican status
I am trying to look at the nican can status through the ncGetAttr.vi . Well, the input, Attribute ID, is 8000000A ( object status ) and the result is 4003000B.
Consulting the nican programmer reference manual, I have not seen such error ( or warning )...
Someone knows what does it means ?
Regards
(4,331 Views)
I found your error code in the NICAN.h file. It is as follows:
#define NC_ATTR_STATUS 0x8000000A
This alone does not tell us too much. Can you be more explicit about what you are doing? I was not able to find any error codes for 4003000B. Is this an error code?
Hope this helps,
Aaron K.
Application Engineer
(4,331 Views)
Thanks for the answer.
I have found which kind of error is this.
The error: 0x4003000B.
The number 4 indicates that it is a warning.
The number 3 indicates a ACK error.
The number B indicates that a BUS off occured.
It can be found inside the NICAN.H file.
I am sending a file that can explain it better.
Fernando
(4,331 Views)
