python nican.dll function call error
Based on the example in https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHbHCAW&l=en-US I am trying
to access the LIN functions of the NI USB-8476 in the following python script:
#!/usr/bin/env python
from ctypes import *
dll = cdll.LoadLibrary("nican.dll")
linName = c_char_p("LIN0")
linPtr = c_void_p()
dll.ncOpenObject.argtypes = [POINTER(c_char_p), POINTER(c_void_p)]
returnValue = dll.ncOpenObject(linName, linPtr)
resulting in the following error message:
Traceback (most recent call last):
  File "./demo.py", line 15, in <module>
    returnValue = dll.ncOpenObject(byref(linName), linPtr)
ValueError: Procedure called with not enough arguments (8 bytes missing) or wrong calling convention
Thanks for any help.
(9,880 Views)
Noticing that I had skipped over the ncConfig function call, thinking this may be a prior
error I tried to set up the ncConfig call according to the ctypes tutorial at
http://python.net/crew/theller/ctypes/tutorial.html.  I have been unable
to make the ncConfig function recognize the parameter arrays:
linNumAttr = c_ulong(2)
NC_ATTR_START_ON_OPEN = c_ulong(0x80000006)
NC_ATTR_BAUD_RATE = c_ulong(0x80000007)
class linAttrIdList(Structure):
   _fields_ = [("ncAttrStartOnOpenID", c_ulong),("ncAttrBaudRateID", c_ulong)]
linAttrIdList.ncAttrStartOnOpenID = NC_ATTR_START_ON_OPEN
linAttrIdList.ncAttrBaudRateID = NC_ATTR_BAUD_RATE
class linAttrValueList(Structure):
   _fields_ = [("ncAttrStartOnOpen", c_ulong),("ncAttrBaudRate", c_ulong)]
linAttrIdList.ncAttrStartOnOpen = 0
linAttrIdList.ncAttrBaudRate = 9600
linPtr = c_void_p(0)
returnValue = dll.ncConfig(linName, linNumAttr, linAttrIdList, linAttrValueList)
this causes python output:
  File "./demo.py", line 23, in <module>
ctypes.ArgumentError: argument 3: <class 'TypeError'>: Don't know how to convert parameter 3
Again, any help is appreciated, especially any examples of correct python usage of nican.dll.
(9,865 Views)
Hi ADLMB,
Unfortunately the second link you posted is broken. Also, Python is not one of the languages that R&D tests with when designing the NI-CAN driver so there may be more issues like this moving forward with Python. I would encourage you to consider using a more widely adopted language. Looking at the NI-CAN readme, you can use LabWindows/CVI, Visual Basic 6.0, Microsoft C/C++ 6.0 or Borland C/C++. There may be someone of the forums with the specialized knowledge you need, good luck.
Matt
(9,843 Views)
Dear,
  About the access of the nican.dll driver from 'Python'
  Is there already a solution for it.
  We plan to use the NI USB-8473s as hardware interface an drive from a Python program ?
  I also suffer with the same issue like described above here
Thank you for an update,
Wouter
(8,934 Views)
As mentioned above, Python is not one of the languages R&D tests when they design the CAN driver. Again, any language listed in the readme can be used. I've also attached a few other documents you might find useful as well as the documents linked above.
Introduction to Scripting in Perl, Python and Tcl
Advanced Scripting in Perl, Python and Tcl
http://zone.ni.com/devzone/cda/tut/p/id/8911
Call Perl and Python Scripts from LabVIEW
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4PSCAY&l=en-US
I hope this helps! Good luck programming!
Jordan
(8,819 Views)
Hello all,
Have you had any luck with this?  I am attempting to use the USB-8473 for monitoring CAN traffic, and would be greatful for any help.
Thank you
(8,497 Views)
