sbRio embedded CAN ID filtering
Is it possible to implement ID filtering in sbrio 9606 embedded CAN driver?
Are there configuration files or other low level tools to do that job?
Luca
(6,500 Views)
Hi Luca,
would you need to implement something similar to Series2 Filter Mode.vi example for NI-CAN? Or would you need to read only frames having a particular identifier?
I think such a functionality is not available in NI-Industrial Communications for RIO Embedded CAN driver, as explained here. You can read all frames and implement filtering in software to find a particular ID.
I hope this helps!
Licia
(6,482 Views)
I need to enable the low level HW filtering handled by the MPC5200 MSCAN engine. In that way I won't add any overhead to the CPU. SW filtering is not doable on a heavy loaded CAN bus.
Thanks for the idea anyway.
Luca
(6,476 Views)
