sending U8 and SGL in same message - Frame API
I am using the Frame API and want to send a message that contains the following information
 Payload length - 8 bytes (most likely)
byte 0 - cmd ID
byte 1 + 2  - unit ID
byte  3 - selection
byte 4-7  - coefficient
I have the first 4 bytes working because I take a string, convert it to byte array and insert each byte in the U8 array.  The problem that I am trying to solve is to be able to have the first 4 bytes be U8 and the next 4 bytes hold the coefficient which is stored in a single precision floating point number.  How do I setup the write message starting from position 4 in the payload to properly send the SGL coefficient?  Can a SGL be packed into the 4 byte payload?  I figured it could because 4 bytes =32 bits and a SGL is a 32 bit number.  I am confused because the Write block takes in a U8 array as the data input.
Gary
(6,483 Views)
Accepted by topic author glstill
I realized that all I need to do is cast the byte array as a single precision floating point number.
(6,476 Views)
