simulate test using without CAN TOOL using labview
   Any one let me know, shall we generate test modal and do test (IG)via lab view, with out using CANOE tool??
(2,698 Views)
LabVIEW is a programming language.  If I ask the question:  Can I generate test models and do IG testing in VisualStudio?  The answer is "yes" but with lots of work.  If you are looking at doing modeling NI would probably recommend you look at Veristand which is NI's software package for doing HIL testing.  I've had little experience with it but it sounds like what you are looking for.
(2,679 Views)
