solution for PCI-8511CAN/LS2 XNET not comatible with NI CAN driver
Hello to all,
I am using an NI PCI-8511CAN/LS2 xnet card and my application is using the NI CAN frame api , I would like to find a solution to run my application correctly with the NI PCI-8511 CAN/LS2.
is the installation of the NI xnet can compatibility and the NI CAN sufficient?
Thank you,
Houssemeddine Snoussi
LabVIEW Associate Developer || TestStand Certified Developer
(2,894 Views)
Accepted by topic author HoussemeddineSnoussi
The problem is solved with the installation of The NI Xnet Can compatibility package and NI CAN.
Thank you,
(2,876 Views)
