switch bounce with pci 1407
I plan to connect a mechanical switch to the trigger input of the pci 1407.
Do I need to take any special steps to prevent switch bounce effects.
If I do what are they and I don't why not?
Thank you very much,
tom
(3,995 Views)
Tom,
You should be fine as long as you bounce effects stay within the bounds of TTL levels.
Austin Talley
Applications Engineering
(3,995 Views)
Can you tell what you mean by
...."bounce effects stay within the bounds of TTL levels"
thanks ,
tom
(3,995 Views)
The Specification for the trigger input are listed on page A-2 External Connections.
Imaq Pci/PXI 1407 User Manual
A. Talley
(3,995 Views)
